Cruise control
Cruise control
On the cruise control for the lt1, does the throttle cable from the gas pedal go to the cruise unit? And whats that black little box right behind the throttle body on the cable? What do the two wires do on it? I'd like to wire up a switch that will engage it to hold the throttle, then i'll just use the brake to release it.
On cars without ASR, the throttle cable goes from the pedal to the throttle body. The cruise has another cable that also attaches to the throttle body. The black "box" is just a cover to keep foreign material from jamming the throttle.
I can send you a bunch of diagrams and such for the cruise. They are for a 93 though. I dont know if they changed much between the years.
What's ASR? I think mine might've had it since I think the cruise cable hooks on to where the throttle cable goes on the throttle body.
Originally posted by kevmor99
Can you please send me those, I'll see if they match up with what I got.
oh, maybe what I'm thinking is a cruise control motor is the ASR, is the ASR a silver cylinder looking thing, a plug with two wires, and 3 pulleys for cables, one being plastic on the end?
Thanks for the diagrams, so does cavity A get B+ power momentarily to switch it on? I wonder if it would work if I had that always have B+, and just used one momentary switch for the SET button, then it'd release w/ the brake.
