crossthreaded head bolt???
durring my header installation, i think i might have cross threaded a bolt that goes through the exhaust manifold into the head,,what would happen if i did? is that repairable?
-Jason
-Jason
Tapping is using a special drill bit almost that when slowly turned in, it will either fix the threads that were messed up or create new ones. You'll have to find out what size threads are used in the cylinder heads. I have one that is cross threaded right now and I just left it, so far so good.
Aaron
Aaron
Originally posted by S.J.S.
Dude if you don't even know what tapping is then I would take it to a shop and let them figure it out. The reason I say that is you don't wanna experiment and mess it up.
I ran into the same prolem tonight with mt SLP install, However it was only the first threas or two. I chased them but chasing a cross threaded hole takes a lot of experience and practice to not further damade the thread. The size is 3/8-16 and they are only about 1/2 in deep so use a bottom tap
