Crankshaft Pulley
Old Aug 31, 2005 | 10:14 PM
JAG05's Avatar
Crankshaft Pulley
I just bought a set of underdrive pulleys from a person on the forum. But it didn't come with bolts so I need to get bolts. While I jack my car up and get under it and I couldn't get one of the bolts off cause my air tool wasn't powerful enought so I found out its a 5/8th. I want and bought three longer 5/8th bolts and when i put them up to the underdrive pulley they are to big for the holes. So what size bolt do I need?
Old Sep 1, 2005 | 01:02 AM
sssalah's Avatar
Re: Crankshaft Pulley
I believe the thread is 7/16" unc but the hex head is 5/8".
Old Sep 1, 2005 | 09:29 AM
JAG05's Avatar
OK that sounds about right cause the auto part store said the stock size was a 7/16th, but the head i know was a 5/8ths.
Old Sep 1, 2005 | 05:16 PM
JAG05's Avatar
Can I just use a 7/16th bolt and put a washer with it? Will that be strong enought to put on the crank?
Old Sep 1, 2005 | 05:18 PM
94zgreenmachine's Avatar
Better use the same grade bolts. I would say at least a grade 5 bolt, but you can never go wrong with a grade 8.
Old Sep 1, 2005 | 05:21 PM
JAG05's Avatar
Yeah I would use a grade 8 maybe a dollar more but I would feel much better about it. Should I use a flat washer or a locking washer?
Old Sep 1, 2005 | 05:30 PM
If you have an ace hardware, they should have a grade 8 bolt with the flanged head, just like the stock ones. Other wise , I would use a washer.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
Slayer
Aug 17, 2015 03:55 PM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
