crankshaft position sensor?
Old Feb 17, 2005 | 10:29 PM
96birdlt1's Avatar
I have a crankshaft position sensor code tripping my service engine soon light. I have replaced the CP sensor, and it still trips the code. I also have a 96 LT1 which has the cps reluctor ring, if that helps any.
My question is what can be causing this and does this code affect driveability at all?
Any ideas would be great
Joe
Old Feb 17, 2005 | 10:52 PM
atljar's Avatar
Re: crankshaft position sensor?
It wont affect driveability at all, its only used for misfire detection.
I dont know much else about them, hopefully someone else will chime in.
Old Feb 18, 2005 | 01:52 AM
97silvermaro's Avatar
get it replaced quick!!! when mine was messin up on my car the car would cut off goin down the road and sometimes if i went to crank it the car would turn over but never crank. i replaced the CP sensor and havent had any trouble for about 4-5 months now.
Old Feb 18, 2005 | 01:53 AM
o i c youve already replaced it...
Old Feb 18, 2005 | 07:34 AM
On the LT1, the crank sensor has nothing to do with engine control as atljar said. You can even run the engine without one. Most other cars will not run without it.
If there was some sort of problem with the wiring or sensor that caused interference on the pink/black lead back to the PCM, then it might cause a driveability problem.
96birdlt1: make sure the pink wire to the sensor has 12v with the key ON. If necessary, you might have to check the continuity of the other two wires back to the PCM. You also need to state what DTC you are getting.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
