crankshaft position sensor
Old Jun 27, 2004 | 06:44 PM
slverbullet's Avatar
k, i kept getting a code for a bad crankshaft position sensor. p0336 i think. dont remember for sure, but anyways... ordered a new one. put it in yesterday and its still showing the code (came up again after being reset, twice!). i know its only for detecting misfires and isnt hurting the engine at all, but would still like to fix this problem. that way i can clear the light and know when another problem arises. any ideas?
dave
Old Jun 27, 2004 | 10:38 PM
A couple things you can do is make sure you see a ground on the pink/blk wire and 12v on the pink wire when the key is on. The yellow wire is the sensor signal feed to the PCM.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
