Cranking precautions?
Old Feb 13, 2008 | 11:09 AM
B-Rad420's Avatar
My engine has been sitting for a bit with no valve covers on it (need tool to clearance them) and my mother desided to use the blower in our carport. What should I do to this motor before I crank it? I am not talking about mud in the heads or anything just maybe some debris or leaf particles. Engine is out of car now. Thanks
Old Feb 13, 2008 | 11:40 AM
ss.slp.ls1's Avatar
Just clean up the heads with a rag as best you can, wiping around all the rockers, valves, springs, etc. Then you can change the oil after running it for a little while. You should be fine, a little dust won't hurt.
Old Feb 13, 2008 | 12:01 PM
B-Rad420's Avatar
What types of "foreign objects' in an engine cause spun bearings? Should I maybe just turn it over alot with the starter and change the oil then and maybe run really thin oil or something?
Jeff1904
Jun 5, 2016 05:00 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
jackpawt883
Sep 10, 2015 08:53 PM
