Crank sensor?
Old Aug 16, 2005 | 08:20 AM
eeg3's Avatar
Crank sensor?
I was getting my knock sensor swapped out last night, and my friend saw that there's an unhooked up sensor near the crankshaft. Is that the 'crank sensor'? I tried searching the forums and found a little help from shoebox saying that the crank sensor was for misfire detection. Do I need to hook it up, or is it ok unhooked?
Background info on the car: 94 z28 exhaust/computer/body with a 96 engine swap so some of the sensors might be OBDI and some might be OBDII. (which is why I changed the knock sensor) Is the crank sensor only used in OBDII, because there doesn't seem to be a cable to plug in?
Old Aug 16, 2005 | 08:24 AM
Re: Crank sensor?
The crank sensor is OBD-II only.
Old Aug 16, 2005 | 08:25 AM
Re: Crank sensor?
The 94 does not have a crank position sensor. They were added in 96 to the OBD-II cars for misfire detection. There is no misfire detection in a 94/95 OBD-I. Leave it unhooked.
Old Aug 16, 2005 | 08:51 AM
eeg3's Avatar
Re: Crank sensor?
8am is always the best time to post because shoebox and Injuneer are checking the forums.
Thanks, fellas.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
Queens94z28
Dec 20, 2014 09:11 PM
Kev@ramchargers
Aug 15, 2002 04:10 PM
