Crank Seal Leaking...already replaced three times!!!
Old Jun 3, 2004 | 10:06 PM
xxsaint69x's Avatar
WTF? what can be causing the crank seal to leak? I already changed it 3 times. Any secrets?
Old Jun 3, 2004 | 10:12 PM
Spinner's Avatar
Not related, but your old motor's about to come back to life. Almost done with all the preperations, waiting on LE heads.
Old Jun 3, 2004 | 10:51 PM
xxsaint69x's Avatar
you got my motor! I want it back! hehehe
Old Jun 3, 2004 | 10:52 PM
The only secret I know of is not to bend it when installing it. OTOH, if your hub has a bad groove in it where it meets the seal, it's gonna leak. I believe you can get a repair sleeve to cover a worn hub surface.
Old Jun 3, 2004 | 11:28 PM
Spinner's Avatar
Yeah... the shortblock anyway from... someone in Jonesboro (forgot his name). Brought it up here, cleaned it up... waiting on lloyd to finish heads to bring it to life
Old Jun 3, 2004 | 11:58 PM
OBE1 95Z28's Avatar
Are you positive that it's your crank seal? On my friend's TA it turned out to be the timing chain cover gasket. The water pump seal is also famous for leaking. I suggest you add dye to your oil and verify your leak source with a black light.
Old Jun 4, 2004 | 10:30 AM
xxsaint69x's Avatar
i guess ill give that a shot....so tired of pulling the hub on/off
It probably takes about 15 min to change the seal hehehe
Old Jun 4, 2004 | 10:31 AM
xxsaint69x's Avatar
any pics of if it all cleaned up ?
Old Jun 4, 2004 | 12:42 PM
Spinner's Avatar
It's on a stand, bagged and waiting heads. I'll post some pics after I get them on it
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
1LEThumper
Jul 14, 2003 12:45 PM
