Crank Pulley Squeeking, ok do wd-40??
Old Mar 11, 2004 | 12:21 AM
96redformula7's Avatar
Question Crank Pulley Squeeking, ok do wd-40??
Well After searching for a screach, squeeking I tracked it down under the car to around the pulley's. I figured that it was comoing from the crank pulley from my hearing, sprayed wd40 and walah! Squeek all gone, I let it run for a bout 5minutes with no more noise. It was cool to use wd40 right?
Old Mar 11, 2004 | 03:51 AM
94m5's Avatar
Well, It can't hurt anything other than breaking down the rubber in the belt. Your squeaking was prolly comming from an old drive belt anyway. If thats the case, replace it.
Mike
Old Mar 11, 2004 | 06:00 AM
funina91ss's Avatar
I had a new belt on mine and is was making a faint sqeaking noise and I sprayed mine and it has been fine ever since then. I did it about 3k miles ago.
Old Mar 11, 2004 | 11:31 PM
No I should correct myself. I didn't spray the belt it is fairly new, less than a year. I sprayed the crank pulley itself the back part of it.
Old Mar 12, 2004 | 12:15 AM
S.J.S.'s Avatar
got a question...was it like a lil chirping sound?? I got one and it seems like its only when I'm stopped and the car is in gear. When I put it in neutral or park...nada.
Old Mar 12, 2004 | 12:17 AM
Yep, that is what is sounded like, a chirping. It is All gone now!
Old Mar 12, 2004 | 01:58 AM
Tair's Avatar
On my 95 Honda Passport a belt was actually too loose, so it was slipping and causing a chirping sound as well. Tightened it up and it was all g.
jbert55
Oct 31, 2015 03:52 PM
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
4586
Aug 18, 2015 07:08 AM
Slayer
Aug 17, 2015 03:55 PM
Catmaigne
Jul 14, 2015 05:17 PM
