Crank pulley install...
Old Aug 13, 2003 | 04:08 PM
Myxtreme1's Avatar
I need to know what is the best way to re-install my cranks pulley. I an putting my car back together from removing the old opti. Thanks for any help!!
Old Aug 13, 2003 | 04:38 PM
Rich_z28's Avatar
Just put the 3 bolts in and tighten them down a little at a time. That way it will walk it in without binding any of the bolts. I also took some emery cloth and cleaned the inside of the pully up. If you do this be sure that all you're doing is cleaning the surface and not gouging it. So get some fine grit.
Old Aug 13, 2003 | 05:02 PM
Myxtreme1's Avatar
Re: Crank pulley install...
Thats what I did. Thanks!
jbert55
Oct 31, 2015 03:52 PM
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
4586
Aug 18, 2015 07:08 AM
Slayer
Aug 17, 2015 03:55 PM
Catmaigne
Jul 14, 2015 05:17 PM
