crank pulley can i blast and paint?
Old Jul 8, 2012 | 04:43 PM
facstk17's Avatar
Just like the title says can i blast and paint a crankshaft pulley?
Old Jul 8, 2012 | 07:57 PM
96capricemgr's Avatar
Re: crank pulley can i blast and paint?
what year?
Old Jul 8, 2012 | 09:27 PM
facstk17's Avatar
1996 ss
Old Jul 9, 2012 | 07:16 AM
facstk17's Avatar
Has anybody ever done this? Will it affect the way the belt spins on the pulley or the pulley fitting back into place?
Old Jul 10, 2012 | 07:52 AM
Stay away from the rubber insulator when you blast and don't paint where the belt rides. Don't overpaint the area on the back where it mounts to the hub.
Old Jul 10, 2012 | 08:35 AM
You know you still haven't actually told us what you are driving, signatures help a LOT. There are a handful of Impala SS owners around here.
Really though blasting and painting the damper itself is a poor idea. Why don't you look up a new replacement from the parts store, no shipping fresh paint and it will be new not some half worn out stock piece.
Blasting the damper is such a bad idea that the first time I read it I actually assumed you meant the hub, not what you said atall but blasting the hub and paining it would have been reasonable so that is where my mind went. There were several length hubs depending on year and application.
Old Jul 12, 2012 | 08:07 AM
Lt1son's Avatar
Honestly im doing a motor on my car now and left the crank pulley alone. Your not going to see it when the motor is in the car atleast on f-bodies. but if you decide to shoebox hit it dead on.
I dont think it looks horrible with a little surface rust gives it class lol
Old Jul 12, 2012 | 10:10 AM
Bersaglieri's Avatar
The salt water makes our boat anchors a little rusty
If the build doesn't require a ATI damper, then I say leave it alone. My 383 has a ATI, my daily driver build has a rusty.
-Dustin-
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
Rde Bandit
Mar 21, 2015 10:17 PM
