Crank Pulley
Old Aug 6, 2003 | 09:19 PM
darkoverlift's Avatar
Crank Pulley
I got a crank pulley.. The belt says hypertech on the outside of it, but it may not be the original case, but it is as worn as the belt is.. Either way I got it… Are they easy to install? I heard some need longer bolts do they all since I assume this is the piggy back styled one. Any tips or hints on install? Or is it remove bolts, put new one on and old one over it..
Old Aug 6, 2003 | 09:22 PM
AsianSensation's Avatar
For a 97, you will need a harmonic balancer pulley puller to rmove the ceank pulley.
Old Aug 6, 2003 | 09:39 PM
cost for this little tool? anyone know? no pb blaster and it will slide off
Old Aug 6, 2003 | 09:44 PM
jasons93z's Avatar
you can get a loaner from autozone for free.
Old Aug 6, 2003 | 09:46 PM
LPEdave's Avatar
You'd only need the puller if, like you say, "PB blaster and slide it off" doesn't work. Mine came right off without any particular trouble, it probably depends how much rust you've got on there.
Yes, you need three longer bolts, sounds like they didn't come with the pulley. Just get good grade 8 bolts from the hardware store, make sure they're not too long or you could drive one into your opti. Other than that, the install should be cake...
Dave
Old Aug 6, 2003 | 10:33 PM
CamaroBoy96Z28's Avatar
I tried the pulley puller but you need a specific size and I dont quite remember what it was but the Auto Zone one was too small or they didnt have the correct one in at the time. Hit the pulley with a hammer, it does the same job. This is probably the only time I'll say use a hammer. That hub aint coming off so it should be fine to give the balancer a good whack.
Old Aug 7, 2003 | 06:52 AM
Any idea on how much longer a bolt should be
jbert55
Oct 31, 2015 03:52 PM
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
4586
Aug 18, 2015 07:08 AM
Slayer
Aug 17, 2015 03:55 PM
Catmaigne
Jul 14, 2015 05:17 PM
