Crank Position sensor question
Old Oct 29, 2004 | 08:04 PM
obiwan76's Avatar
I am doing an Lt1 swap from a 95 model to a 97 model after i spun a bearing.
I was needing to know if i need to hook anything up to the CPS if I use the 95 harness. The 95 does not have a Crank Position Sensor or the plug in the harness to use it. My main question is it vital and will the engine run properly without it plugged in. I have the engine in the car and am at a dead end until I find out what to do about the CPS
Old Oct 29, 2004 | 08:36 PM
Josh-'04 GTO's Avatar
Re: Crank Position sensor question
If you're using the '95 PCM, then you won't need the CPS.
Old Oct 29, 2004 | 08:37 PM
obiwan76's Avatar
Thank you SOOOO much that was what i was worried about... =)
Old Oct 29, 2004 | 08:50 PM
I should clarify a little. If you have a California car, then a '95 will have OBD II, and therefore a CPS requirement in the PCM. But odds are you should be all set. Just leave it unplugged with the sensor in place so that you won't have to change the timing cover.
Old Oct 29, 2004 | 08:57 PM
Let's clarify your clarification.
No 1995 LT1 f-bodies had OBDII. They are all OBDI, California emissions or no.
Old Oct 29, 2004 | 09:20 PM
95 California cars had dual cats, right? Maybe I shouldn't be assuming that dual cats = OBD II equipped?
Old Oct 29, 2004 | 10:07 PM
The 1995 California emissions automatic equipped cars had dual cats, but were still OBDI.
Old Oct 30, 2004 | 06:29 PM
Ahhhh... I see. Damn you Shoebox. Next time I'll quit when I'm ahead.
Old Nov 1, 2004 | 01:38 PM
remaxracer45's Avatar
ShoeBox is GOD!!! Am I understanding this to be if I have a 97 Z28 with a madwolf obd1 conversion I have no need for the crank position sensor?
Thanks Shawn
Old Nov 1, 2004 | 02:57 PM
madwolf's Avatar
Thanks Shawn
Yep, you can leave it disconnected if you want.
Old Nov 1, 2004 | 07:58 PM
Thanks for the intel Ion!!!!
PS anyone need tuning you are STILL the man!!!!
PSS 410 gears for my A4 in the spring??????
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
