crank hub removal
Old Mar 11, 2007 | 02:03 PM
camzaro28's Avatar
crank hub removal
I have been on shbox site all day, best site by far ( next to CZ28.com ) but this hub has me stumped.
I followed what his site says, I am using the 3 jaw puller and have turned it 8 or so times and it just wont budge. There is alot of resistance. Am I doing something wrong or do I keep going and it will give at some point?
Old Mar 11, 2007 | 02:12 PM
You only use a 3 jaw puller to remove the pulley, not the hub. If you keep going like you are, something is probably going to break. What are you actually needing to do?
Old Mar 11, 2007 | 02:15 PM
camzaro28's Avatar
Damn
Trying to get the hub off to get the timing cover, etc off.
Old Mar 11, 2007 | 02:21 PM
Dave89IROC's Avatar
Originally Posted by camzaro28
Damn
well, you need a hub puller, uses 3 bolts to attach to the hub, has a screw in the middle
then, you need to get a logn bolt/rod to fit through the center hole, so you are pushing on the crank, not the threads or the hub
look at this pic for what the hub looks like
Edit, heres the pic, from shoeboxes site
Old Mar 11, 2007 | 02:23 PM
camzaro28's Avatar
ah, there is a bolt inside of the hub, I take it I need to take that out first?
Old Mar 11, 2007 | 02:27 PM
That would be a big, yes.
Old Mar 11, 2007 | 02:35 PM
camzaro28's Avatar
Haha, can you tell this is my first time doing this?
Well I got that bolt out! So Guess its time to go to advanced and rent the hub tool
This is the first issue I have ran into, so I think I am doing alright so far.
Thanks alot guys
Old Mar 12, 2007 | 08:25 AM
camzaro28's Avatar
Well there isnt a shop in town with this tool. I am going to have to drive nearly an hour to get one.
Before I go I would like to know if any crank hub removal tool will work? Are they universal?
Old Mar 12, 2007 | 10:53 AM
Any SBC damper removal tool will work, but you might have to open the slots a little for the larger bolts used to secure the pulley on the LT1 hub. Follow the directions that Dave89IROC gave.
Old Mar 12, 2007 | 01:23 PM
camzaro28's Avatar
Yeah I have the right tool now, but ran into the problem you just noted!
The bolts are too big for the slots
Old Mar 12, 2007 | 03:12 PM
An alternative that some have used is to use longer and thinner bolts that pass through the threaded holes in the hub. Put a nut and washer on the back side and make sure they are all turned out to the same length.
Old Mar 12, 2007 | 03:54 PM
dfa_crunch's Avatar
hey man dont feel bad, the first time i did this i didnt have a hub puller and me and my stepfather improvised. it came off but i also got hit in the head and had a pretty big bump
Old Mar 12, 2007 | 10:40 PM
camzaro28's Avatar
Still cant get it off. We did what you are saying bout the smaller bolt and nut. That thing is stuck on there. Sprayed it with some PB blaster, going to let it sit over night.
This thing is a PITA
Old Mar 12, 2007 | 10:50 PM
black95z0122's Avatar
you can try heating it if your going to take the timing cover off and replace the gaskets/seals on the timing cover. Try some good penetrating oil too.
(not at the same time)
Old Mar 13, 2007 | 10:38 AM
ChevalierSS's Avatar
Make sure the center crew on the puller is pushing against the crank and not the hub. I inserted a long bolt (longer than the hub bolt) into the crank and threaded it all the way down to push against.
