crank hub
Old Jul 3, 2006 | 07:41 AM
teekettle's Avatar
crank hub
The hub has two marks on it from the seal, not groves but lines. do i need a sleeve saver or will it be ok.
Old Jul 3, 2006 | 08:53 AM
Kevin Blown 95 TA's Avatar
Re: crank hub
Hard to tell with no picture. Get someone to chuck it up in a lathe and clean it up for you.
Old Jul 3, 2006 | 09:34 AM
Blue96z28's Avatar
Re: crank hub
If you can't catch the grooves with your fingernail your probably ok. Mine had some slight grooving @ 100k when I took it out, but I just rocked it back on with a new seal, and not a drop since.
AviatorDave
Dec 19, 2016 06:35 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
Catmaigne
Jul 14, 2015 05:17 PM
