crank balancer
Old Apr 30, 2004 | 12:16 PM
whiteZ2895's Avatar
crank balancer
does anyone know how to get the harmonic ballancer off i tryed a puller and other stuff but nothing works
Old Apr 30, 2004 | 12:26 PM
Naegash's Avatar
You have to use a puller in conjunction with a very long, very narrow bolt. It has to fit all the way inside the balancer and touch the actual crank. None of the bolts that came with my puller could accomplish this, so I had to go buy one that would. After I got the right bolt it came off rather easily.
Old Apr 30, 2004 | 04:33 PM
Pullngz's Avatar
Balancer should come off fairly easy, The crank snout is what most people have a problem with. Might not be the right way to do it, but I usually slightly tap the balancer with a hammer.
Mike
Old Apr 30, 2004 | 04:38 PM
Bersaglieri's Avatar
Mine was rusted on solid. I had to use a puller (brake type I think) my uncle gave me. I pulls from the outside with 3 arms instead of the 3 inside bolts since the LT1 balancer is a 2 peice. And you dont need to pull the hub, usually.
-Dustin-
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Catmaigne
Jul 14, 2015 05:17 PM
