crane valve springs
Old Jan 7, 2006 | 10:43 PM
194bird's Avatar
crane valve springs
need some help i just bought the lt1 valve spring kit from crane cam i have never done valve springs before was just wondering if some one could give me some tips about how they did it and about the shims and stuff
thanks brad
Old Jan 8, 2006 | 01:43 AM
sssalah's Avatar
Re: crane valve springs
thanks brad
You need to get spring locators for this kit as it has none. Also you'll need a good spring compressor if your attemting to swap them in the car, I've have the new crane compressor that does 2 springs at a time, and lathough it's a bit pricey it makes this jod easy.
The shims should be used below the locators to correct for installed hight that is usually measured by a spring micrometer.
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
