Crane says not to use guide plates???
Old Jan 24, 2007 | 09:35 PM
dannyum89's Avatar
Im putting my new 383 engine together as we speak. For valve train I have a CC306, CC beehives, Magnum PR, CC High Energy Hydraulic Roller Lifters and Crane Gold Race Roller Rockers PN#10758. CraneCams claims this. Do not use with pushrod guideplates or with cylinder head castings that guide the pushrods, as severe pushrod wear will occur Thats pretty simple to understand but my CC. PR's say, for use with guideplates!? Am I that stupid that I can't make sense of this. There has to be a simple explaination that im not getting.
Old Jan 24, 2007 | 09:36 PM
speed_demon24's Avatar
If they are self aligning rockers dont use guideplates, if they are non-self aligning rockers use guideplates.
Old Jan 24, 2007 | 09:37 PM
SStrokerAce's Avatar
Nope, what rocker arms are you running? If they are self algining rockers then DON'T RUN GUIDEPLATES!!!!
Bret
Old Jan 24, 2007 | 09:50 PM
matLT1's Avatar
Yeah, sounds like you have the self-aligning (will have what looks like a washer on each side of the roller tip) rockers to me. In which case you do NOT use guide plates.
Old Jan 24, 2007 | 10:02 PM
dannyum89's Avatar
Yeah, its the SA rocker arms. I wasn't too sure.
Hey Bret! You should have known better. I already told you which rocker arms I was gonna run. Im the guy that got one of your Hemi springs! LOL
Old Jan 24, 2007 | 10:04 PM
The new one is on the way too!!!! It should be there Friday.
Yeah you don't need the guideplates!
Bret
Old Jan 24, 2007 | 10:23 PM
dannyum89's Avatar
You should have your Hemi spring back tomorrow.
Old Jan 25, 2007 | 11:04 AM
mzgp5x's Avatar
I've been running the Crane golds SA rockers. No guide plates. With addded spring load, I also used head bolt washers under the rocker studs and lock tite. I had some studs go loose, and, the Rooler rockers will change angle and cause a Hertzian stress failure on the valve tappet(s). The washers (ARP from Summit) have worked for me. I lock-tite everything (red and blue). Also, take note of the head bolt washer chamfer on the top side that mates with the rocker stud chamfer. (383 - D1 - AFR) Hope this helps.
Old Jan 25, 2007 | 06:54 PM
marshall93z's Avatar
What would happen if you DID run the guideplates also?
Old Jan 25, 2007 | 07:55 PM
tfperf's Avatar
Baaaaddd things!!
Old Jan 25, 2007 | 08:01 PM
MeanGreen97Z's Avatar
Valvetrain bind and severe wear on the guideplates, valves, pushrods (possibly bend them), and studs. It's not something you want to do.
95chwagon
Oct 16, 2015 12:24 PM
NewsBot
Sep 30, 2015 04:20 PM
95blkss
Sep 22, 2015 03:18 PM
NewsBot
Sep 14, 2015 09:20 AM
Aaront810
Sep 11, 2015 11:24 AM
