Crane Lifter Adjustment (high-performance HD rollers)
About my Comp 918 Beehives,they are new! I got the engine running in September last fall (everything new) and ran it in about four bracket races. Then only two runs at the track last Sunday. Bert Chambers (Moore Machine, 12th Street) set-up the springs on the AFR heads. Therefore, I can't believe those springs are "completely" at fault here.
Additionally, I also have a set of the dual-spring Comps (new in the box). However, when Bert checked them, they didn't meet the published Comp spec for lift (less-than .580 actual).
WD
Warren,
Yeah usually the Comp Beehives last longer than that, but still go in and check your seated height pressures on them. What you are discribing is a perfect sign of valve float and I've seen that before on those lobes. MAKE SURE it's not that before you rule it out.
I've had the beehives keep their pressure 20,000miles so normally they work flawlessly, that's due to the good kobe quality spring wire.
Bret
Bret
Here is another theory on what could be causing my high RPM problem (momentary “hit/miss” in 2nd gear around 6100, “during heavy load” just prior to shift).
One of the local performance machinists (Bert Chambers) thinks the problem is pre-detonation due to the 12.2-1 compression and not enough octane. And, that I should be using 110 octane with that compression ratio. Also, the 104 octane I’m using is from last fall (maybe lost points over the winter?) and possibly the reason this problem was worse this first time out. I had some minor symptoms of the same problem last fall, but not this bad.
Bert also thought HD valve train float wouldn’t be just a momentary hit, it would fall flat. I’ll probably still reduce the lifter pre-load to 1/4 turn (from 1/2) and go to 110 octane to see if that helps.
WD
WD
WD
WD
GO to 7,000 and see if it stays.
Don't think ya need fuel. Figure your DCR.
Have run 13/1 on pump gas and the DCR is determined by the cam. Stay below 9.0DCR.
It won't fall flat unless it's ALL of the valves or at least half. If it's 1-2 valves and the rest are right on the edge then it will be a miss.
