Are Crane Gold roller rockers self-adjusting??
Old Apr 25, 2004 | 03:29 AM
ishz28's Avatar
I was wondering if I have to readjust my 1.6 rockers or are they self adjusting? Thanks.
Old Apr 25, 2004 | 03:42 AM
ABA383's Avatar
Not sure about your question...If you are adding Crane rockers then you obviously must initially adjust them by going to zero lash, then 1/2 turn more and then lock the poly locks...Hydraulic systems should not require constant adjusting...My LPE motor's valves haven't been adjusted since Lingenfelter himself ran the valves in 1995...If you mean self aligning then that depends on if you are using guide plates...Self Aligning rockers do not use guide plates to keep the roller on the valve tip...Hope I've made sense...
--Alan
Old Apr 25, 2004 | 04:17 AM
ishz28's Avatar
Thanks for the reply. The rockers have been on the car for about four years now. They tick just a bit louder when there's fresh oil in the car (no tapping, just ticking). I figured that was just the nature of them, heard aftermarket rockers will tick louder than stock. Unless they do need adjustment. I am using a hydralic lift Compucam 210/224.
Old Apr 25, 2004 | 07:49 AM
ABA383's Avatar
You are welcome...Its better to be a tad on the loose side than too tight anyway...btw I'm using an LPE 211/219 .533int .560exh thats been in since '95 and hasn't needed to be adjusted yet...take care..
--Alan
Old Apr 25, 2004 | 06:10 PM
ishz28's Avatar
Cool...
Old Apr 25, 2004 | 11:43 PM
96LT14u2Nv's Avatar
the gold races are self-ALIGNING. not adjusting. but the ticking is normal. a self aligning rocker is noisier by nature
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
