crane gold Roller rocker fulcrum?
Old Sep 24, 2008 | 07:40 PM
pyro719's Avatar
Witch way does the fucrum go on the stud? Flat side up or round side with machined lip up? The instructions say flat side up but why does it have a machined lip in the rounded end?
Old Sep 24, 2008 | 07:43 PM
mdacton's Avatar
flat side up. the nut needs a flat surface to seat on
matLT1's Avatar
I'm not certain about the machined lip, but the flat side of the fulcrum goes up so the polylock has a flat contact surface to tighten against.
Old Sep 24, 2008 | 07:50 PM
pyro719's Avatar
I had them installed with the round part with the lip up before, If I try to use the flat side it seems like the polu locks will botom out on the rocker
Old Sep 24, 2008 | 08:00 PM
pyro719's Avatar
The round side with machined lip has to go up. If I install the flat sid up the 5/8 nut on the poly lock goes inside the rocker body and the rocker is still lose
Old Sep 24, 2008 | 08:04 PM
mdacton's Avatar
then you need different locks or something is not right
Old Sep 24, 2008 | 08:08 PM
pyro719's Avatar
They are the locks that came with the rockers brand new.
Old Sep 24, 2008 | 08:09 PM
mdacton's Avatar
Well I don't know what you want to hear.....
Put em like you had them
Old Sep 24, 2008 | 08:13 PM
SnakeOiler's Avatar
is the set screw backed out?
Old Sep 24, 2008 | 08:15 PM
pyro719's Avatar
I would just like to know if these are supposed to be installed with the flat side up or the round side with machined lip? Why would there be a machined lip on the round side? It looks like the lip is there for the poly lock to sit on? They are crane gold 1.6 self aligning roller rockers.
Old Sep 24, 2008 | 08:18 PM
pyro719's Avatar
Yup took the set screw completly out, The problem is when I install a rocker with the flat part of the fulcrum up I have to screw it in alot and the hex head is just about hitting the rocker body. With the round side up the poly lock only screws down about 5 or 6 turns before zero lash.
Old Sep 24, 2008 | 08:29 PM
SnakeOiler's Avatar
You say it "seems like" they bottom out. A picture says a thousand words. post one.
Old Sep 24, 2008 | 08:49 PM
pyro719's Avatar
http://i170.photobucket.com/albums/u...9/PDRM0952.jpg
http://i170.photobucket.com/albums/u...9/PDRM0953.jpg
http://i170.photobucket.com/albums/u...9/PDRM0949.jpg
http://i170.photobucket.com/albums/u...9/PDRM0950.jpg
http://i170.photobucket.com/albums/u...9/PDRM0951.jpg
the front rocker is at zero lash with the fulcrum flat part up
the back rocker is at zero lash with the fulcrum round part up
Seems like the hex is to close to the rocker body on the front rocker?
Old Sep 24, 2008 | 08:57 PM
Kevin Blown 95 TA's Avatar
Flat side up. They are fine if the hex isnt touching the rocker anywhere. Yours look like all the ones I've done. Keep in mind if they are touching in the bottom where the nut touches the flat part - they are all going to be the same and have the same clearance. That isnt dependant on the adjustment unless the nut is really loose.
Also, you can get taller posilocks but then you just need taller valve covers, so they try to keep them not too high if possible.
Old Sep 24, 2008 | 09:10 PM
pyro719's Avatar
Cool I'll tryem out with the flat side up. Thanks Guys.
