cracked head????
Old Jul 4, 2009 | 11:12 AM
badgn's Avatar
cracked head????
I was just gettin on the highway when i heard a major exhaust leak... It same out of nowhere... Got the car back home and figured i had blown out the old header gasket... I bought a new set... dead soft aluminum.. put them on and still have a big exhaust leak... the leak is on the pass side rear of the head... seems like it is comin out of the "extra" header bolt hole on the last port??? These are pretty new heads from Lloyd elliott.. not even 1000 miles yet and now this.... Does this make sens to anyone?? The gasket i took out was in fact bad but the new one def shoulda sealed that up... Am i supposed to put a plug in it or something???
thanks
jeremy
Old Jul 4, 2009 | 11:24 AM
Mr.GearheadZ28's Avatar
It could possibly be your Y-pipe bolts are loosely connected to the headers/exhaust manifold.
Old Jul 4, 2009 | 11:29 AM
badgn's Avatar
no its def from this bolt hole/area... everything else is tight and i just started it and could hear it... I put my hand all over and this is where i could feel the air comin out... what a pain in the ***...
Old Jul 4, 2009 | 09:25 PM
Are you sure its not the EGR pipe (if your headers have an EGR port)?
Old Jul 5, 2009 | 03:26 AM
Air-Adam's Avatar
Is the header flange straight? What headers?
Old Jul 6, 2009 | 09:43 AM
Diamhea's Avatar
I had the same problem, persistent header leak....bought locking header bolts and percy gaskets, still leaked. Turns out the crappy *** headers were warped. Bought new headers and it went away.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jlo
Feb 3, 2015 09:41 PM
Chris Anderson
Jan 27, 2015 08:30 AM
squarehead
Nov 21, 2014 08:02 PM
