CR increase with .26 gaskets
Old Jan 7, 2007 | 11:58 PM
Maro Boy Ken's Avatar
What will my compression ratio increase be over stock if I went with the thinner gaskets, is it safe? Ill be using le3 cam and le2 heads? 91 octane?
Old Jan 8, 2007 | 12:20 AM
Z-RATED94's Avatar
3 or 4 tenths I believe, all else being the same. And no I don't think you will have a problem on 91 octane.
Old Jan 8, 2007 | 01:11 AM
seawolf06's Avatar
Depends on your combustion chamber size.
Old Jan 9, 2007 | 09:47 PM
le2 heads I think 54-56cc
Old Jan 9, 2007 | 10:11 PM
seawolf06's Avatar
Since they're custom heads, you should ask Lloyd and then he can help you figure out your SCR and then DCR with your cam.
Old Jan 10, 2007 | 12:27 AM
sbs's Avatar
sbs
LE2 are 57cc
I calculated it as 10.6:1 on a stock bottom end and .026 gaskets, but Brett and Lloyd have posted on here that LE2 gives 11.0-11.2:1 with that setup.
Old Jan 10, 2007 | 02:19 AM
seawolf06's Avatar
I think they mean that the LE2 should be run with 11-11.2:1 compression for best results.
Old Jan 10, 2007 | 03:21 AM
sbs's Avatar
sbs
Either of those two would talk about DCR not SCR for "best results."
Also, the "best results" SCR for an LE2 package would be higher than 11-11.2:1.
Oh, and we can also look at what they actually said:
Originally Posted by SStrokerAce
It's low 11's compression James.
http://web.camaross.com/forums/showt...e2+compression
Originally Posted by Javier97Z28
From Lloyd:
"A stock bottom end 350 with my LE2 heads and cam will be right at 11.1 to 11.2 to 1 with the .026 Mr Gasket # 5716 head gaskets."
http://web.camaross.com/forums/showt...ompression+le2
Old Jan 10, 2007 | 04:00 PM
seawolf06's Avatar
Ok, but I doubt the 57cc chambers then, more like 55cc.
Old Jan 10, 2007 | 05:10 PM
Mortify's Avatar
What would the increase be on stock heads?
Old Jan 10, 2007 | 09:51 PM
sbs's Avatar
sbs
Dude you really need to stop talking out your a** about stuff you know nothing about.
I _have_ LE2 heads, and Lloyd told me they are 57cc. In addition you can search this forum and find the same information in a number of posts.
This time I'm not doing the search for you.
Old Jan 10, 2007 | 09:56 PM
sbs's Avatar
sbs
I get 11.0:1 using the calculator on this site.
Old Jan 10, 2007 | 11:34 PM
Thanks so probably 11:1
Old Jan 11, 2007 | 12:10 AM
seawolf06's Avatar
I understand, but with 57cc on a stock bottom end you're gonna get more like 10.8:1. I'm not trying to get into a pissing match with you and you can quote all the posts you want. I just want the guy who started the thread to get the best info possible.
Old Jan 11, 2007 | 09:56 AM
Z-RATED94's Avatar
Steve, do you really believe each an every set of Lloyds LT1 stock ported heads all have the same size chamber? Guess again, because mine are a little smaller than 57cc.
