Could it be the radiator?
Old Oct 4, 2004 | 11:23 AM
Dee94Z28's Avatar
I have 94 z28. Last week the car started to spit coolant out of the reserve tank. Some people have stated that the radiator cap could be bad or a blown head gasket can cause that problem. Last night when I was checking the radiator out I notice a small hole spitting out coolant and air about an inch below the radiator cap could this be my problem
94 Z28
Moroso CAI
BMR strut tower brace
1LE elbow
Magnaflow catback
Carsound hiflow cat
Old Oct 4, 2004 | 01:31 PM
Fuels94TA's Avatar
Re: Could it be the radiator?
Well if your seeing coolant coming out from under the neck area then yes you need another radiator. The radiator tanks can't be fix cause it's plastic, now you can rig something temporary like weld puddy and see if it close the small hole in the tank. If the coolant does hold from the tank, and you still see coolant coming out from the overfill tank then it can be a bad cap, or head gasket.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
