Could false knock feel like a very bad miss?
Old May 25, 2004 | 08:43 PM
smoknta's Avatar
I've got a very bad miss at high rpms now that i put my new exhaust on. One of the pipes is hitting the under side of the car pretty bad on hard accelleration. Could this be causing false knock? And if so can false knock feel like a very bad miss?
Old May 25, 2004 | 08:53 PM
BPS's Avatar
BPS
Missing at high RPM - sounds like an ignition issue
false knock causes retard and a loss of power buut not a miss.
I used to get it a lot at acceleration from traffic lights - the car would stumble and have little power - Got a scanmaster and discover 10 degrees of retard was occuring
you may have a tired coil or ignition system (if your running one) - arcing/ poorly gapped plug or opti issues
Old May 25, 2004 | 08:58 PM
smoknta's Avatar
its hard to tell what is happening, i have'nt had a chance to put it on a scanner yet. But it only happens when the exhaust hits, so it is hard to tell what is going on. But i can tell a dramatic decrease in power. Everything on the car is very new. Motor only has about 1500 miles. Same milage on everthing including opti, wires, coil. Plugs dont even have about 100 miles on them. The problem got real noticible whent the exhaut was put on.
Old May 27, 2004 | 09:57 AM
"White Knight"'s Avatar
Yes it can feel like a miss. They do feel a little different but are very close. If you think you have false knock oder a LT4 knock module.....you won't be sorry........makes the car more consitant and i knocked off .3 in the 1/4 due to false knock issues (headers)
Old May 27, 2004 | 07:42 PM
smoknta's Avatar
I have a 93, they do not have knock modules like the they have in the 94 and ups.
Old May 27, 2004 | 08:02 PM
I doubt you will feel anything that seems like a miss from knock retard. It retards the timing, not cuts out any spark. About the only thing you would notice is that the power was down.
maybe2fast
Mar 13, 2015 11:48 AM
DetroitZ28
Feb 13, 2015 07:33 AM
karnykamaro
Feb 2, 2015 01:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
