Corvette LT 1 engine leaking
Old Aug 20, 2006 | 12:55 PM
night-rider-69's Avatar
Hello!
A few years ago I installed a Corvette LT 1 engine in my 69'Camaro.
I think because of the narrow engine bay of the Corvette there's an adapter at the oil filter, which move the filter closer to the engine.
I want to have a look to this adapter and since then it's leaking. I tried several times to fix (new seals etc) but without any success. Especially at the bolts there are always oil drops.
Because at the Camaro there's enough space I want to eliminate this adapter. But sorry I don't know this detail from a "normal" small block=>
Is there a "normal" adapter from the block => oil filter or better a direct connection flange possibility to the hoses from my separate oil filter unit.
Thanks for help
Detailed pictures from a standard (LT1 F-body) small block are welcome!
Old Aug 20, 2006 | 01:49 PM
bingo's Avatar
Re: Corvette LT 1 engine leaking
You can get the fitting from almost any small block chevy. There are two bolts that hold the adapter. Remove the old one and intall the new one. I did this on mine when I took off the oil cooler. If you search posts for oil cooler removal you will most likely find pics.
Moshbmx1
Jan 20, 2015 03:27 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
Bearmans
Dec 3, 2014 05:28 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
