Correct way to install starter..
Old Apr 10, 2003 | 09:52 AM
96z's Avatar
96z
Is there a wrong or correct way to reinstall the starter or do you just have to line it up and bolt it in?
Old Apr 10, 2003 | 01:48 PM
96z's Avatar
96z
Anyone? I thought I read that its important to do this a certain way.
Old Apr 10, 2003 | 01:57 PM
This is what you want to achieve. Use shims if needed.
Now, what do most people do? They slap it on and hope for the best. Most of the time, that is good enough, as long as you don't have any grinding or engagement problems.
Old Apr 10, 2003 | 02:08 PM
JWA95TA's Avatar
I nver understood that. If it came from the factory without shims, seems like yo could put it back on without shims?? The haynes manual says to use shims but never says why. Glad you cleard that up for me shoebox
Jason
Old Apr 10, 2003 | 02:43 PM
96z's Avatar
96z
Thanks Rob, Ill make sure everything is lined up good than.
Old Apr 10, 2003 | 04:15 PM
96ZRDR's Avatar
Just make sure your power wire is not making contact to your ground wire on the solenoid. If not, it will try to crank when trying to connect the battery.
Old Apr 10, 2003 | 06:41 PM
Brent94Z's Avatar
Super Moderator
I've just bolted mine up on my F-Bods with no problems
96ZRDR, if you could shorten up your sig, it would be appreciated! If you can get it down to around 5 lines it would be even better
Old Apr 11, 2003 | 08:01 AM
96ZRDR's Avatar
What, I am very proud of my mods. This things cost money and time.
No problem.
Old Apr 11, 2003 | 08:06 AM
No problem.
Some people use tinier fonts to help. Actually, the forum rules are maximum 5 lines.
Old Apr 11, 2003 | 09:37 AM
Brent94Z's Avatar
Super Moderator
No problem.
Thanks!
What you can do is sign up for a FREE camaroz28.com web page or reader's rides page, display all your mods there and some pictures, then put a link to that page in your sig.
Old Apr 11, 2003 | 09:44 AM
dabear95's Avatar
I used a small paper clip to gauge the clearance. Worked great!
Old Apr 11, 2003 | 10:17 AM
x7x7's Avatar
My stock one had no shims so I reinstalled the replacement without shims and haven't had a problem.
Nov 18, 2023 07:21 PM
sloppytot
Feb 25, 2015 08:30 PM
Collector Car
Jan 5, 2015 10:58 AM
Jul 4, 2005 05:00 PM
CamaroKiddZ28
Aug 7, 2002 10:17 PM
