Correct PCM voltage?
Old 09-06-2004, 05:11 PM
TobyZ28's Avatar
What should the PCM in freescan read for voltage at Idle and when running? My car at idle is low 12V and at 3000 RPM on the highway is around 12.8 at the most. These readings were taken from freescan. If I have the Power inverter plugged in for my laptop and the AC on i've seen the voltage drop to 11.6 ish.
Is the voltage reported by the PCM gernally very accurate? Is it a sensor i can test and /or replace? Do I need a new alternator?
TobyZ28 is offline
Old 09-06-2004, 05:18 PM
Re: Correct PCM voltage?
There is no sensor. It just reads voltage incoming to the PCM, itself. Sometimes diagnostics can report the voltage a little low for some reason. Compare the reading to a digital meter connected at the battery to check for accuracy.
shoebox is offline
Old 09-06-2004, 05:24 PM
RobbyRob's Avatar
I'm changing my alternator. Mine shows it dropping off down 10 & 11 volts. Not good for making power. Powermaster alternator has sent me part #'s for my Z.
Here are the part #. 17805 chrome 140 amp,
27805 chrome, natural, black 200 amp
RobbyRob is offline
Old 09-07-2004, 11:42 AM
TobyZ28's Avatar
Well i had the voltmeter up against the battery and it was pretty solid above 14 volts with highbeams, AC on high while idling.... Seems like freescan (or perhaps the pcm) is steadly off by 1.5 volts.... Thnx shoebox
TobyZ28 is offline
Old 09-07-2004, 05:01 PM
RobbyRob's Avatar
Mine has shown drops in voltage off the alt and batt. When a/c lights or fog lights. Not just 1 volt.
RobbyRob is offline
Boss002
01-20-2016 12:17 PM
88IROC_Z
07-22-2015 11:38 PM
C4m4roJoe
07-19-2015 10:59 PM
Dark Zeiro
07-19-2015 08:25 AM
gonzo275rltw
07-11-2015 04:19 AM
Quick Reply: Correct PCM voltage?
