Correct opti orientation for install
Is there and or what is the correct way to put the opti back on? On the motor side of the opti there is a couple holes and slots. Which one is the correct one to use and does the cam dowel pin need to be in a certain postion when the opti is installed?
The dowel can be anywhere as long as the special slot on the opti drive goes over it.
CARiD
Jan 27, 2015 06:27 AM
