correct MAP voltage KOEO?
Old Jan 14, 2004 | 10:18 PM
BobRocket's Avatar
Can somebody please verify the correct voltage output of the MAP sensor with the key on and engine off? (the voltage on the center wire)
I have a 94Z and noticed it shows 30 kpa on my scantool with the Key on, engine off. Its also putting 4.8 volts out on that center output wire. (also has 4.8 or so in from the pcm on the left wire).
The car will not start, has wet gas fowled plugs and I'm suspicious this is the problem...
Old Jan 14, 2004 | 10:23 PM
Are you sure that is not barometric pressure you are reading? That would be more like it if it reads 30. That also would correspond to the ~4.8v reading you are getting. Both would be normal.
Old Jan 14, 2004 | 10:29 PM
BobRocket's Avatar
probably your right... Always get the two confused.
Why would it be at 30 before starting? I only hit 30 when at WOT, and then mostly 27-29... That would add way too much fuel for startup, correct?
Bob
Old Jan 14, 2004 | 10:35 PM
It reads the current barometric pressure when you first turn the key on. That is then the baseline it uses for further calculations. When you start the engine, the vacuum produced inside is then compared to that reading.
When you are at WOT, there is very little vacuum in the manifold and you are much closer to atmospheric pressure.
Fred has some explanation here.
Old Jan 14, 2004 | 10:55 PM
MentalCaseOne's Avatar
Straight from my Scan Tool report
Key ON engine Off
with my old MAP sensor 4.91 volts
Barometric 4.91 volts
With my new MAP sensor 4.82 volts
Barometric 4.82 volts
both scannings done at the same altitude.
30Hg you mean? It should be at 30Hg. The MAP sensor reads the barometric pressure inside your intake manifold. with the engine off there is no vacum and the outside air pressure (BAR) will force air pass the throttle body and will balance your inside intake manifold pressure with the outside air pressure.
Negative my little grasshopper.. MAP sensor reading is not the only one that dictates how much GAS is pumped into the cylinder.
The PCM needs to know How much air is entering the engine first. remember the fuel is calculated by a mass of air and a mass of fuel... the so called air to fuel ratio.
MAP sensor readings indicate the amount of load your engine maybe experiencing.
Check this webpage out. This will give you a better idea of the role of the MAP sensor in an engine:
http://www3.autozone.com/servlet/UiB...3d8004f7cf.jsp
I hope this info helps
Marvin
Old Jan 14, 2004 | 11:08 PM
BobRocket's Avatar
I'm used the turbo buicks... We dont have MAPs that play a role in the tuning (we use Load, LV8)
Thanks guys!
Bob
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
tdigger9899
Sep 7, 2015 10:56 AM
