Correct gap?
Old Apr 28, 2004 | 07:02 PM
guywithaZ's Avatar
Correct gap?
I am going to put in a set of 104 autolite plugs...not 103s because I have no power adder...but I do have all the bolt ons you can get without cracking the engine open...so I figured the 104s will work...yes or no?...so my question is what would you gap the 104s at...from my searching I saw someone say they gap them at .035 is that a little small or will that work...thanks
Old Apr 28, 2004 | 07:44 PM
GreenDemon's Avatar
Well, anything between .035 and .050 should work fine...
My Hayne's says .050
My Chilton's says .035
The general consensus around here is .050 for na cars. Since the LT1 ignition is on the weak side you may want to gap a little less.
Too large of a gap will make the spark weak and will result in poor combustion and poor performance- get yourself an ignition amplifier or LS1 style and that problem is solved...
Too small of a gap and the spark is powerful, but it's not very spread out, so improper combustion could result from that as well.
.035 is a little on the small side, but it should work regardless.
Old Apr 28, 2004 | 08:52 PM
Look on the sticker on your radiator cover. It says spark plug gap is .050.
Old Apr 28, 2004 | 09:06 PM
guywithaZ's Avatar
I've got an accel system on it with coil does that make a difference...or is the stock gapping ok...thanks
Old Apr 28, 2004 | 09:08 PM
I would stay with the stock gap.
Old Apr 28, 2004 | 09:10 PM
GreenDemon's Avatar
No the stock gap will be fine. High compression levels are what usually neccessitate adjusting the gap smaller than stock (for reliable spark).
guywithaZ's Avatar
stock it is...thanks...
Aaront810
Aug 29, 2020 09:34 PM
drt
Sep 27, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
