cooling problem
Old Aug 31, 2005 | 03:29 PM
cmking26's Avatar
cooling problem
I added coolant through the water pump and everything I added ran right out the back of the block. I have the coolant crossover tube on nice and tight, any ideas why it would run out like that?
Old Aug 31, 2005 | 07:01 PM
cmking26's Avatar
Re: cooling problem
Ok I found that the passenger side coolant crossover bolt went in on an angle. Its a new bolt so how can I fix this? Should I run a tap through the hole or can the tube being bent a little cause this?
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
