cooling fans not coming on...problem solved
Old Jun 20, 2007 | 12:28 PM
transAMdriv3r's Avatar
I recently have been seeing trends with overheating cause of the cooling fans being inop for the last month. Mine has been doing this since I owned the car, so last year I made a switch to turn them on manually.
Just today I was reading some of the trends and many replied to switch the relays for the fog lights and the cooling fans, I did that. I also seen to replace the fuses even though they might look to be good, I did that as well. Finally someone stated to pull the pcm bat fuse and replace it as well.
I dont know which one fix it, but it worked, got the car up to half way between 210 and 240 and they came on. I also had a new coolant temp sensor at the waterpump put in.
This site just amazes me
linz
3rd Gen / L98 Engine Tech
Apr 7, 2015 11:49 AM
MattFick
Feb 15, 2015 10:16 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
