Cooling Fan relay
Cooling Fan relay
I threw a code - 77- which is cooling fan relay. Problem is I have three of them in the box. Are they in any sequence - i.e. would #1 go out first, etc. or will I have to get them all checked????
Without knowing how your switch is wired, there is no way to troubleshoot that part any further. The PCM gets it's temp reading from the sensor in the water pump. The PCM, itself, is what turns on the fans.
That's odd because my problem began when I replaced the temp sensor. I just checked the plugin wire and it is plugged in tight. Is there any way to test the wire itself and/or the sensor to make sure it is OK. It just seems odd that the changing of the sensor and the fan problem began at the same time. The fans haven't kicked in by themselves since then.
