cooling
Old Oct 17, 2003 | 06:06 PM
Hershball's Avatar
cooling
My fans arn't kicking on!!!!!!!!!!!!!!!!!!!! any ideas?????????????????????????????
Old Oct 17, 2003 | 06:51 PM
ny_z28man's Avatar
Cooling fan relay probably went. Also check your fan fuses. Test the relay ports and see if your getting power. Then use a jumper wire and see if the fans will start when you jump the power to the load side. If you dont want to test it replace the relay, thats usually the case. Hope this helps, see-ya.
-Paul
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 17, 2015 08:31 AM
cmsmith
Sep 14, 2015 09:09 PM
damnyankee36
Sep 9, 2015 07:06 PM
