Cooling
Old Sep 3, 2003 | 02:44 PM
djn's Avatar
djn
Cooling
Car runs hot with the AC turned off. Doesn't overheat with it off but runs well into the 200's when ideling for more than 5-min's
Need help Thanks...
Old Sep 3, 2003 | 02:53 PM
BlakeW5's Avatar
Are you low on coolant? Also, your fans could not be working. Has your car thrown a code?
Old Sep 3, 2003 | 03:08 PM
djn's Avatar
djn
Coolant Level is fine. No codes yet but could be the fan. I hear the fan start with the AC on but I don't hear it start when the AC if off.
Old Sep 3, 2003 | 03:19 PM
RamAir95TA's Avatar
Confusing?
Your primary fans don't turn on until 215 degrees, and the secondary speed kicks on around ~225. These cars are designed to run hot for emissions purposes. What you're experiencing is a most likely normal condition.
Those of us with modified cooling systems see temperatures no higher than 170 degrees, regardless of running conditions.
Old Sep 3, 2003 | 03:37 PM
anaik's Avatar
Actually they kick in at 226 and 235.
http://csce.uark.edu/~jgbertr/rb/4th...2.html#cooling
Old Sep 3, 2003 | 03:44 PM
djn's Avatar
djn
Thanks, first time owner of a Z28. I appreciate the help..
Old Sep 3, 2003 | 03:45 PM
RamAir95TA's Avatar
Close enough.
Old Sep 3, 2003 | 03:58 PM
BigRich's Avatar
setting them to come on at 180-185 works like a charm
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 17, 2015 08:31 AM
cmsmith
Sep 14, 2015 09:09 PM
damnyankee36
Sep 9, 2015 07:06 PM
