Coolant Smell
Old Mar 25, 2003 | 07:01 PM
curt'95Z's Avatar
Coolant Smell
I changed my water pump six months ago and did a radiator flush, but I am still smelling coolant from the engine after shut down. I don't see any signs of leakage around the hoses. Is there a problem area unique to LT-1's that I should be looking for?
Old Mar 25, 2003 | 11:16 PM
fbird95's Avatar
My 88 caprice had a similar issue. I would always smell it after i turned the car off. No one could ever track it down and the car didnt loose collant over time for the most part, so i stopped caring about it. Maybe you have luck like me, as long as your not lossing coolant dont worry too much about it unless it worsens.
Old Mar 25, 2003 | 11:44 PM
Wild1's Avatar
I'd go to the autoparts store and rent a radiator pressure tester. They are free with a deposit. Top off the coolant with Distilled Water from the grocery store... not hose water that has deposits. Pressurize it to the rating on the cap and wait. You'll see the drip.
Let us know what you find. Any smell means there is a leak. Even a small leak means that coolant is escaping or another way to put it... it is loosing pressure. When the pressure drops, you'll boil at a lower temperature causing hot spots in the water jacket that surrounds the cylinder walls and won't be able to carry away the heat.
Check with a pressure tester, it could save you some $$$ in the long run!
Old Mar 29, 2003 | 02:22 AM
curt'95Z's Avatar
Thanks for the advice on the pressure tester - I'll try it this weekend.
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
