Coolant overfolw
Old Nov 26, 2003 | 08:39 PM
KillWhitey's Avatar
Coolant overfolw
Today I was driving home to change my oil when i noticed the smell of coolant. when i looked, it was dripping from the engine. I couldnt find anywhere it was leaking from. I pulled the battery out to see if there was a hole in my overflow. The hose from the box to the radaitiator was so corroded that i could not even see it. I pulled it out, cleaned it up and sure enough, that was the problem. How much does the overfolw cost?
Old Nov 26, 2003 | 08:54 PM
S.J.S.'s Avatar
I'd like to know the same thing. I know you have to buy it one piece with the battery mount.
Old Nov 27, 2003 | 10:50 AM
KillWhitey's Avatar
Could i Just block off the overflow from the system? Is it really that important?
Old Nov 27, 2003 | 11:07 AM
predator's Avatar
NO if you block it off when the radiator build to much pressure the coolant would have no place to go to releive the pressure. hence to much pressure = blowed radiator and or overheating probs
Old Nov 27, 2003 | 11:08 AM
predator's Avatar
the cap works as a valve when the pressure gets to much the collant goes into the recovery once the pressure in the radiator drops it opns again and sucks the coolant out of the overflow back into the radiator
Old Nov 27, 2003 | 03:43 PM
KillWhitey's Avatar
So...how muchy does the part cost?
Old Nov 27, 2003 | 03:44 PM
KillWhitey's Avatar
Part number?
Old Nov 27, 2003 | 04:02 PM
CamaroBoy96Z28's Avatar
Mine was $33 at the dealer. Dont have a p/n, they should just be able to look it up for you.
Old Nov 27, 2003 | 04:07 PM
jasons93z's Avatar
Did you look at the waterpump, it could be coolant coming out of the weap hole
Old Nov 27, 2003 | 04:37 PM
KillWhitey's Avatar
I checked the water pump first, it is not leaking.
Old Nov 28, 2003 | 11:34 AM
KillWhitey's Avatar
I got the part at a dealership for about 35.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
