Coolant in the oil.. Fixable?
Old Mar 9, 2008 | 04:10 PM
95camaro3800's Avatar
I've been chasing down a missfire for a week on this motor, and I just checked the oil (earlier in the week it was good and black) now it's watery, and smells like coolant.
It also blows alot of blue smoke out the tail pipes.
Haven't checked to see if theres oil in the coolant yet, the motor is still a bit warm.
Is this a head gasket leak? Intake gasket leak? How do I tell?
What should I do, to see if it's saveable or not?
Old Mar 9, 2008 | 04:23 PM
95LT1conv's Avatar
Definately sounds like a head gasket, but also sounds like you are getting a lot of oil past the piston rings. Coolant getting into that cylinder could have tore something up pretty good. Only way to be sure is pulling heads, which it sounds like you willneed to do anyway.
Old Mar 9, 2008 | 05:13 PM
Ironxcross's Avatar
Consider an LT1 swap! (if you really have a 3800)
Old Mar 9, 2008 | 05:47 PM
mrmint69's Avatar
I think he has a different car than the one in the signature so he needs to tell us this each time which one he's taliking about. A blown headgasket is bad for either a v6 or v8 but thats my guess as will most agree.
Old Mar 9, 2008 | 06:33 PM
NEVERMIND.
It's gas in the oil, I think, mixed with some really fine metal shavings.
Took off the valve covers, and here's what I found:
Old Mar 9, 2008 | 07:35 PM
mrmint69's Avatar
Well you found a problem. Be sure what ever you do that you don't run the car with the gas in you oil. Be sure to change it at least 2 times when you fix it.
Old Mar 12, 2008 | 06:03 AM
Turned out it was lifter failure, all the internals popped out of it.
Got it back together, and runs on 8 cylinders again!
Old Mar 12, 2008 | 08:19 AM
2000GTP's Avatar
Good that you got it together. Did you notice any damage to the cam lobe from the failed lifter?
Old Mar 12, 2008 | 11:46 AM
ajschult's Avatar
Were they comp r's?
Old Mar 12, 2008 | 09:57 PM
Never got to look at the cam, didn't need to. Just needed to pull the remainder of the lifter out, and put a new one in.
And the lifters are Federal Moguls.
Old Mar 13, 2008 | 12:41 PM
G. McDonald's Avatar
Are those non-self aligning rockers?
I can't really tell for sure from the picture, but they look as if they are non-self aligning which would require you to run guide plates (which you don't have). Guide plates also require hardened pushrods, as you probably know.
Others that are more knowledgeable than I am will want to chime in, but if they are NSA rockers and you do not have guide plates, then that may well be the source of your problem.
Best of luck.
Old Mar 13, 2008 | 12:44 PM
AHARTZ28's Avatar
Best of luck.
they are self aligning....
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
