Coolant in the oil AND the exhaust
Old Jan 23, 2004 | 08:03 PM
96speed's Avatar
I'm 95% sure I have a blown head gasket (at least), however, I'd like to have some backup on troubleshooting the coolant in the oil.
How certain is it that I have a cracked block?
tia,
Ryan
Old Jan 23, 2004 | 09:04 PM
Josh-'04 GTO's Avatar
The odds are you just have a blown head gasket, not a cracked block. Pull the heads off and have them Magnafluxed and surfaced, and put it back together....with new gaskets of course!
Old Jan 23, 2004 | 09:07 PM
SiDeWaYZz28's Avatar
one more vote on headgasket
Old Jan 23, 2004 | 10:23 PM
JDBlaze85's Avatar
95% head gasket
5% block
Old Jan 23, 2004 | 10:51 PM
will62085's Avatar
i would deffinatly pull the heads off and check that out first, and dont drive the car too much, too much coolant in the oil/cylinders can cause the motor to hydrolock...then its time for a rebuild...just got done with that after mine locked up...good luck
Old Jan 23, 2004 | 11:43 PM
97 RedSS's Avatar
Sux to hear bro but only good things can come from bad
Its time to stroke it
Cody
Old Jan 24, 2004 | 01:05 AM
96speed's Avatar
Cody...LOL.
I don't see how coolant can get into the oil from the headgasket, but I don't know much about anything either .
The heads are definitely getting yanked - I'm putting the car on jackstands for now.
Ryan
Old Jan 24, 2004 | 01:10 AM
Red_94Formula's Avatar
blocks dont crack unless they are bored over. coolant can get into oil by this: the piston rings are worn. coolant collects in the cynlinder. coolant seeps down past the piston rings and into the oil pan.
btw: its a head gasket
Old Jan 24, 2004 | 01:17 AM
will62085's Avatar
ide jsut put new gaskets in it, and have the heads machined...you can get blowby on a new motor with new rings...there designed to compress air, not liquid...BTW, how many miles are on the motor?
Old Jan 25, 2004 | 09:22 PM
96speed's Avatar
As I suspected, it was a head gasket failure. Cylinders 7 & 8 were getting coolant.
http://images.cardomain.com/member_i...79_88_full.jpg
http://images.cardomain.com/member_i...79_89_full.jpg
Hoping to be rocking this weekend .
Ryan
Old Jan 25, 2004 | 09:26 PM
will62085's Avatar
two blown out, on seperate banks??...thats crazy....glad you figured it out though, good luck getting it goin again
Old Jan 25, 2004 | 10:53 PM
97 RedSS's Avatar
1st pick looks to be the side that was leaking through..other pic looks like the signs of the coolant getting on the gasket from pulling the head..I wouldnt think you would have both sides pop a gasket...unless it overheated..
Glad thats all it is..
Cody
Old Jan 25, 2004 | 11:12 PM
96speed's Avatar
Smile
Judging by the valves on the heads along with the gaskets, both gaskets failed. The car overheated for about 2-3 minutes a month ago.
Oh well..so much for a bling 383 short block .
Ryan
captcorvette
Mar 7, 2015 12:37 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
MattFick
Feb 15, 2015 10:16 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Sandersen511
Jan 13, 2015 03:49 PM
