coolant in oil
Old May 23, 2013 | 01:11 PM
MadDsahZ28's Avatar
Exclamation coolant in oil
shes been parked for a month as I am currently replacing my headers and misc parts went to drain the oil and coolant started dripping from the plug no oil mixed in I got about a cup of coolant out followed by a cup of mixed oil coolant then just oil car ran fine when it wanted to cause of bad sensors no sweet smell spark plugs were bone dry and no oil in the coolant could it be a head gasket on its way out or something bigger wanting someones .02 worth
as some of you ma know I do not have much wheel time on her so I don't know if this a recent problem or if it is a old problem from the previous owner was bought a few months ago
mike
Old May 24, 2013 | 08:36 PM
Kevin Blown 95 TA's Avatar
Re: coolant in oil
I'll let someone else say it.
Old May 24, 2013 | 09:27 PM
CALL911's Avatar
Re: coolant in oil
Blown head gasket.
Old May 24, 2013 | 10:39 PM
LT4Monsta's Avatar
Re: coolant in oil
Sounds like the previous owner pulled one on you. That doesn't just happen overnight. Especially on the LT1. All that coolant has been cycling through your oil causing additional wear on any part that depends on that oil to keep it properly lubricated. Cam shaft bearings, crankshaft bearings, lifters, rockers, etc, etc. Depending on the miles on it who knows how bad it might really be or how long it has been going on.
Old May 25, 2013 | 04:57 PM
MadDsahZ28's Avatar
Re: coolant in oil
odometer says 150,xxx carfax says theres a odometer discrepancy that was reported in 2011 last known mileage was 147,xxx from a dealer I think joe blow had two of these and mixed them up as far as mileage besides the engine problems the car is clean thanks for the help pulled the heads today waiting on new gaskets and head bolts
Old May 27, 2013 | 09:55 PM
LT4Monsta's Avatar
Re: coolant in oil
Glad to hear you tore it down so quickly. Why you're down that far you should try to pull the camshaft and check it for wear along with the bearings if you can. Also check those lifters to see if there are any chips or abrasions on the rollers.
Also, a lot of times with the LT1 leak half the gunk is trapped in the oil pan. When my head gasket popped I never knew. Couldn't even tell on oil changes till I dropped the pan and found the answer.
Good luck!
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
FredM
Jun 5, 2015 05:45 AM
Nickster 7
May 1, 2015 09:04 PM
MattFick
Feb 15, 2015 10:16 PM
