Coolant Line behind the heads...
Old Apr 28, 2005 | 02:11 AM
JeremyZ28's Avatar
Best way to remove the brackets for the coolant line behind the heads? Need to get the heads off and this is the only thing still connecting it, had a hell of a time trying to get a wrench back in there. Any tips? Also that sensor right below the bracket, whats it for? It threads right into the block.
Old Apr 28, 2005 | 02:33 AM
Red on Red WS6's Avatar
Re: Coolant Line behind the heads...
Try a closed wrench or a socket. The last ones I took off striped out. If it does not unbolt very easy pull the heads off together with it still attached.
Old Apr 28, 2005 | 02:40 AM
onecrazygm's Avatar
it's a 15mm if you cant it off it might be striped... if not pull the heads off all at once.. with some help .. then take it off with vice grips.. go to a gm dealer and get new ones
Old Apr 28, 2005 | 07:00 AM
94zgreenmachine's Avatar
I had a problem with mine so I cut them on the car. 25 for new ones so I was gonna replace anyhow. It's a pain trying to get both off.
Old Apr 28, 2005 | 09:17 AM
NOMAD's Avatar
I cut all of mine. Any lt-1 that goes together, they get cut. I put about 1" distance between the cuts which allows me enough room to put a piece of hose in there. 2 hose clamps turned the right way and you will never have to remove the steam tubes again. Undo a hose clamp and you can take individual heads off. Put head back on and attached your spliced in piece of hose. Easy.
-Shannon
Old Apr 28, 2005 | 09:18 AM
Blownbird355's Avatar
The sensor is the oil pressure sensor.
Old Apr 28, 2005 | 11:23 AM
Don 97 SS's Avatar
They can be difficult to access, but I managed to get mine with out any damage to the banjo bolt or the lines. I used a long 15mm closed end wrench and used a hand sledge to tap the wrench handle to loosen them.
Old Apr 28, 2005 | 12:00 PM
chevy1963's Avatar
I took all the head bolts out of both heads and had two people pick the heads up at once and removed the lines outside the car. But a 15 mm rachet wrench works great as well
blac94Z
Feb 15, 2021 09:43 PM
calaban
May 18, 2020 06:43 PM
LingenfelterZ28
Apr 24, 2015 12:14 PM
MattFick
Feb 15, 2015 10:16 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
