coolant leak...need help now!
Old Mar 22, 2004 | 10:26 AM
SlickBlack Z's Avatar
I just got home and noticed alot of coolant leaking. Looked under the hood...it appears there is some kind of cap a few inches below the main radiator cap that blew off...coolant was spewing out! What is this...what happened...what should i do?
Old Mar 22, 2004 | 10:41 AM
x7x7's Avatar
coolant temp sensor maybe? there should be a temp sensor that screws into the rad near the top.
Old Mar 22, 2004 | 11:37 AM
Ok...so it seems that the coolant temp sensor just blew off! I clipped it back on...doesnt seems like a very effective connection, all thats holding it in place is a thin metal clip. What could have caused this to happen? Any ideas?
Old Mar 22, 2004 | 12:52 PM
SweetZRag's Avatar
Maybe too much pressure in the radiator? Have your radiator cap tested or replaced.
Old Mar 22, 2004 | 01:06 PM
Coolformula's Avatar
Get a new cap, I dont like autzone etc caps them stant ones look very cheap. I would go to gm there high like 10 bucks but solved my promblem of too much pressure. Also make sure you dont have too much coolant in your system. try that and let usknow.
Old Mar 22, 2004 | 01:39 PM
ttopz28's Avatar
Mine leaks like crazy when I fill it up until it gets to a certain level. I think it's coming from the return line under the battery, but I haven't had the chance to check yet.
Mines on the passenger side, but I can't see where it's coming from by looking under the hood.
Old Mar 23, 2004 | 11:17 PM
cmillard's Avatar
That's the coolant level sensor, not the coolant temp sensor.
The coolant temp sensor is located in the water pump housing.
The coolant gauge sensor is located in the drivers side cylinder head.
Hope this helps,
Christian
Old Mar 23, 2004 | 11:51 PM
x7x7's Avatar
yep, that's what i meant, it's pretty obvious that a level sensor would be near the cap and a temp sensor needs to be closer to what it's reading the temp of.
Old Mar 25, 2004 | 10:46 AM
I guess its true that animals are attracted to the smell of coolant. After my leak the other day, there was alot of residual coolant left under the hood. Today I opened the hood...there was a squirrel chillin on top of my motor! The little bugger didnt want to leave, he ran behind the motor...I was forced to fire up the engine, then he ran away. Just thought id share this random occurance.
Also...does anyone have the GM part# for a new radiator cap?
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
