Coolant fill procedure
Old Mar 7, 2004 | 10:14 AM
rob2299usa's Avatar
Question Coolant fill procedure
I recently finished rebuilding my engine and I'm ready to fill the coolant but I was wondering if there was any special instructions as to how to fill a completely dry system. I want to avoid getting any air pockets...
Old Mar 7, 2004 | 10:36 AM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
I've always had good luck w/ adding the the radiator... Then once it stops letting you add any fluid, loosen the bleeder cap screws and that'll get rid of a lot of the air in the motor.... Then add more. Obviously make sure you don't leak too much water out of the bleeder cap though.
Old Mar 7, 2004 | 10:52 AM
93ZM6Tally's Avatar
I agree with the above procedure but to add to it I always pour water in the top of the water pump before I install the thermostat and "gooseneck". Seems to get very air in the system that way and is easier to bleed.
Old Mar 7, 2004 | 11:24 AM
Some of this might be helpful.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
Pwilson59
Sep 3, 2015 08:47 PM
War Engine
Aug 28, 2015 06:04 AM
Noct
Jul 14, 2015 01:18 AM
