Coolant drain passage
Old Sep 5, 2004 | 03:38 PM
framelayin84's Avatar
Would the coolant drain passages on either side of the block be a good spot to install a water temp probe for a water temp gauge? Also, would the oil passage above the oil filter mount work for an oil pressure sensor for a mechanical oil pressure gauge? Thanks
Old Sep 5, 2004 | 03:44 PM
Re: Coolant drain passage
I guess you could use the drain for a sensor or you could put a "tee" at one of the other sensors.
The port above the oil filter is a good spot for the oil pressure sensor.
Old Sep 5, 2004 | 03:55 PM
I completly forgot about the stock gauge probe location. Thanks shoebox
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
