Coolant Crossover Tube
Old Oct 12, 2005 | 12:46 AM
Bigbegum69's Avatar
This is one of my first posts here but I have gotten some great info off this site.. For starters I did an LT1 Conversion on a 1980 Volvo. Total sleeper..
http://www.cardomain.com/ride/2119951
Those are old pictures. I just need to figure out the cooling system and throttle cable.
So my problem is i forgot to install the Crossover vent tube on the rear of the engine. I have also lost the tube. So either I go to gm and get a new one or I use AN fittings or build a homebrew setup from elliots.
I want to block off the tb coolant inlets and I am using an aluminum resivor for the coolant. What would you do?
Old Oct 12, 2005 | 03:30 AM
blahster's Avatar
Re: Coolant Crossover Tube
I would suggest that you go to gm and get a new one. If i am not mistaken, without it, you won't get proper flow of coolant thru the heads. And you can bypass the TB very easily with a little tube adapter a couple hose clamps. in fact i would recommend bypassing the TB anyway to reduce intake air temps.
Dunno if this helps or not.
Old Oct 12, 2005 | 03:59 AM
jkipp84's Avatar
I agree, replace the cross over tube, it's not something you want missing. I'd order one from Dal (877-448-5451) to get a good price.
blahster, the Navy did the same thing to me many years ago I went ahead and bought my (now gone) 92 RS brand new because the detailer said no problem going to Canada. Of course - I got orders to Okinawa I had fun there though. My dad kept my car safe the 2 years I was out of the country.
Old Oct 12, 2005 | 11:19 AM
Bigbegum69's Avatar
Ok I got the GM crossover tube but now I dont know where to vent it too. My overflow tank has two npt holes. One is for the coolant overflow from the radiator, what if I use the other for the crossover vent?
Thanks for the replies.
Old Oct 12, 2005 | 10:34 PM
blahster's Avatar
not sure if you've seen this or not...but it might be helpful...
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Oct 13, 2005 | 12:55 AM
Bigbegum69's Avatar
Thats a good site but i still dont know where to route the line.
Old Oct 13, 2005 | 05:36 AM
SnakeOiler's Avatar
It should be routed back to the radiator.
Old Oct 13, 2005 | 07:39 AM
JasonK94Z's Avatar
http://shbox.com/1/93-94_hoses.jpg
http://shbox.com/1/95-97_hoses.jpg
Either one of these should help.
Old Oct 13, 2005 | 04:19 PM
Bigbegum69's Avatar
I am using steel flex hose for the radiator and the radiator doesnt have any more inlets. I do not have any of the heater hoses hooked up. Can I just plug it into one of the outlets on the water pump?
Old Oct 13, 2005 | 05:10 PM
Dave89IROC's Avatar
you could run it to the heater return on the W/P, I will get back to you on which one that is
Old Oct 14, 2005 | 01:32 AM
Bigbegum69's Avatar
Thanks man. Has anyone tried tapping a plastic end tank on a radiator. I might just get an elliots fitting for 3/8 hose and tap and epoxy it in. Thanks for all the replies guys.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
cmsmith
Jul 2, 2015 10:26 PM
cmsmith
Mar 16, 2015 02:34 PM
JurisAg02
Jul 27, 2002 11:49 AM
