Coolant Crossmember Problem
Old Oct 14, 2004 | 12:03 PM
CColtManM's Avatar
I don't know if anyone here has has this problem. The coolant crossmember on my car, is leaking with one of the bolts in the back. I spent the money and got brand new washers (the ones with the rubber sealent inside) and new bolts. Goes in great, and i pressure aired it, no leaks. When i poured my coolant in, without pressure and the car off, it began leaking. Has anyone had this problem?
Old Oct 14, 2004 | 12:17 PM
94_Z28_guy's Avatar
Re: Coolant Crossmember Problem
Ive not had this problem.
But maybe its leaking from somewhere other than the bolt/washer. Could the tube be leaking near the fitting?
Old Oct 14, 2004 | 12:21 PM
CColtManM's Avatar
I had the tube off. No holes, not even pinholes.
Old Oct 14, 2004 | 07:03 PM
If you did not clean the surfaces of the head and coolant crossover, you might have leaks.
Old Oct 17, 2004 | 07:39 PM
CColtManM's Avatar
The solution to this problem is... You don't need this cross over pipe. It will make your car run about 5 degrees hotter (towards the throttle body) but no harm will be done. Anyone know why my rockers keep falling off and bending my push rods?
Old Oct 17, 2004 | 09:53 PM
It relieves potential hot spots in the heads from the reverse flow coolant system.
Since you don't seem to think you need it, just leave it off. I would not recommend it, though.
MattFick
Feb 15, 2015 10:16 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
