Coolant cross over tube question
Old Jun 25, 2003 | 10:04 PM
94_Z28_guy's Avatar
Well, I got my heads on and everything else, and was filling up with coolant (just water for now) and I hear it pooring out somewhere. I figured out it was the one side of that stupid coolant crossover pipe on the back of the heads (passenger side leaking where bolt goes in, driver side is fine).
It was a real pita to put pass side on, and it went on pretty tight from the start (not real tight like the bolt was going in crooked, but tight) and I was wondering how tight that thing needs to be bolted on. Also, the order I have put it on was bolt head then a washer with a rubber flange piece sticking out, then the metal circle (part of pipe) the another flat washer with rubber center. It has been so long since I took it off, could someone confirm that is the order? Also, does everyone recommend replacing those washers?
Thanks in advance, I have to get some sleep, so I will check in morning.
BTW I was tapping the wrench gently with a hammer to get it tight, but it could still turn somemore. Maybe I just don't have it tightened enough, but I don't want to strip it since it is aluminum.
Old Jun 26, 2003 | 07:14 AM
94_Z28_guy's Avatar
Anyone? Gotta know if I should go to dealership and buy those washers after work....
Old Jun 26, 2003 | 08:18 AM
Dave Feerst's Avatar
The torque spec is 30 foot pounds
The sandwich order is bolt head, sealing washer, pipe, sealing washer head.
The washers are 5.XX each
Old Aug 30, 2004 | 01:26 PM
BAD 97 WS-6's Avatar
Re: Coolant cross over tube question
I have used M14 washers from Advance Auto. I havent had any leaks and I have used them twice since 2001. They are 4 for $5 Same size as the GM part
Old Aug 30, 2004 | 01:29 PM
ibanez6rg's Avatar
"Crush" washers are what they are.
HectorM52
Jul 30, 2017 11:46 AM
Richardan15
May 30, 2015 08:36 AM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
