cool tip for trans cooler install
Old Apr 19, 2003 | 08:27 AM
ChickenScreamer94's Avatar
Talking cool tip for trans cooler install
i was reading on all the install guides about taking out the fans to put on those zip strap deals, to do it from the radiator side to the engine side, pushing on them in that direction. This would require removal of the fans to get the strap on. Instead, just push the zip strap things in from the fan side of the radiator. This way you dont have to remove the fans. Oh yeah, use some cardboard on the front of the radiator so you dont bend the fins trying to put the cooler on. happy installs!!!
Old Apr 19, 2003 | 11:14 AM
Z28ROC's Avatar
The zip straps have to hit the holes in four corners of the trans cooler to work. So you would have to use a template. But there is no room for it with the fans in the way.
The easiest way is to get the fans out of the way. I only had to remove the passenger side fan.
Also my cooler came with rubber isolator pads.
alex5366
Feb 17, 2015 09:07 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
