Be Cool Rad installed..Now Cant close HOOD!
Old Apr 9, 2005 | 07:17 PM
ledfootz28's Avatar
i just got done putting in the be cool radiator and was ready to take it out when i f'in see that my hood wont close bc the rad cap neck is sitting to high.it will go to the latch position but not close down all the way.
i cut the rubber mount edges off so that it will fit but what else should i do? it says to bend back the bottom radiator support(its flared up a little bit to hold the rad in).thats the only thing i didnt do bc it was fitting fine.im f'ed
any suggestions from ppl with this radiator.
Old Apr 9, 2005 | 09:06 PM
ledfootz28's Avatar
Re: Be Cool Rad installed..Now Cant close HOOD!
NVM after some man handleing it i got it in.i just had to slide it out a bit to get that clearance i needed.things f'in huge
Old Apr 10, 2005 | 10:02 PM
bdc95ta's Avatar
I'd like to see what your talking about can you put up a pic?
-b
CARiD
Jan 14, 2015 04:00 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
